8 Users Online (6 Members):
Forums >> Revit Building >> Technical Support >> View Range
0 Posts No Rating |
I am having trouble with view raange and an opening on my framing plan. I have a door with a 2X8 header bearing -2'-10" below the second level. My associated level is the second level and the cut plane is 1'-0" above the second level. When I change the view depth to -1'-9" the header is no longer visable on plan but the opening still shows up, what am I doing wrong? I am using Revit 2015.
Thanks!
Edited on: Tue, May 23, 2017 at 2:18:05 PM
I think you have no answers because of how you asked your question.
"...if my view depth was set to -1'-9" should the door opening not be seen on plan?.." Are you saying it was seen on plan?
0 Posts No Rating |
Yes, the opening is still showing up with my view depth set to -'1-9".
extending the view depth allow you to see the projection lines of the door not the opening " the symbolic lines indicating the Door Leaf(s) " if you want to see the opening you have to change the cut plane - but what i didn't get is what do you want so i can propose a solution ?
But mostly this issues are solved with a "plan Region" but before using the area plans make sure that you really can't adjust the view range to get all what you want
0 Posts No Rating |
I don't want to see the door opening or the opening "projection lines" on plan. If the view depth is above the "door opening" (-1'-9"), why do I still see the "opening lines"? I thought if the view depth was set above the opening that I would not see anything on the plan. Thanks for your help, sorry if i'm not explaining this well.
view range |
Fri, Sep 7, 2007 at 2:28:04 AM
View Range |
Tue, Aug 28, 2007 at 9:52:27 AM
View Range for Revit Link |
Thu, Nov 12, 2015 at 7:10:18 AM
low wall not displaying correctly with view range |
Fri, Aug 3, 2012 at 4:35:37 PM
In place families above the view range are still appearing |
Tue, Dec 23, 2014 at 9:17:05 AM
