Forums >> Revit Building >> Technical Support >> Showing Windows Above
Wed, May 24, 2006 at 6:38:15 AM | Showing Windows Above
mpenn
1 Stars: 1 Votes
I searched through the forum, but I can't find an answer for my question. I need to show windows that appear above the cut plane. I have the top range set high enough that I can dimension to the centerline of the window, but I would like to be able to see the windows in plan. I have windows at all kinds of different heights...I read in one of the posting something about changing the cut plane range in the window family, but couldn't figure out where to do this... I am sure the answer is simple...I've been using Revit for only a little while, but this little issue is haunting me...
Wed, May 24, 2006 at 6:47:33 AM | RE: Showing Windows Above
coreed
coreed Avatar
4 Stars: 16 Votes
use a plan region around the windows in question and set the cut plane for the plan region HTH Post edited on 2006-05-24 06:55:35
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, May 24, 2006 at 7:35:10 AM | RE: Showing Windows Above
iqlayser
4 Stars: 1 Votes
go into the properties of the plan where the windows are and edit viewrange. sett the cutplan at the "correct" height to alov the windows too appear as u like them to Hope this helps.
Golf anyone?????
Showing windows on the floor plan
Sat, Feb 28, 2009 at 7:07:23 AM
Windows not showing correctly in legend
Mon, Dec 14, 2009 at 5:22:42 PM
Windows showing up gray in consistent colors view.
Tue, Apr 26, 2016 at 11:25:23 AM
13
Windows and doors not showing up in walls
Mon, Nov 8, 2010 at 3:24:05 PM
Windows not showing up in legends
Sat, Mar 3, 2007 at 12:15:36 PM
Page generation time: 0.2276
