Forums >> Community >> Newbies >> Tagging, naming or labeling an extrusion in a family
Fri, May 19, 2017 at 4:04:26 AM | Tagging, naming or labeling an extrusion in a family
PeterV
Hi I'm Peter and quite new to Revit, so far been using it for about 1,5 months and I have a question.
I'm trying to tag each window pannel with a unique something as seen in image 1 within the family, then in the main project you'd be able to better target a spesific glass pannel as seen in image 2. This data should also be able to be exported and the family should be reusable/resizable.
The only sollution i've been able to come up with is by simply giving each glass pannel a different glass material like Glass1 Glass2 Glass3 etc, this however doesn't seem like the best way to go.
Does anyone have a good sollution for this?
Edited on: Fri, May 19, 2017 at 6:57:12 AM
Fri, May 19, 2017 at 1:31:24 PM | Tagging, naming or labeling an extrusion in a family
Individual components are not taggable but nested, shared families are.  Do your research there.
Family Help Please! 'Labeling this dimension would overconstrain the sketch.'
Wed, Jun 10, 2015 at 9:18:40 AM
Can't delete solid extrusion in Family
Fri, Feb 15, 2019 at 11:58:25 AM
Void extrusion family visibility
Fri, Apr 22, 2022 at 7:57:52 AM
Void Extrusion in window family problem
Mon, May 18, 2015 at 3:55:23 PM
parameter naming conventions
Thu, Apr 2, 2015 at 8:44:13 PM
Page generation time: 6.5626
