Forums >> Revit Systems >> Technical Support >> Revit 2017 Text Displaying Differently - Windows 7 & 10
Mon, May 15, 2017 at 2:00:01 AM | Revit 2017 Text Displaying Differently - Windows 7 & 10
raja15
Hi there,
Just wondering if anyone else has noticed differences in the way text behaves in Revit 2017, but in Windows 7 & 10?
Currently in our office:
We have 5+ computers still running Windows 7 - All are using Revit 2017
3 computers have been updated to Windows 10 - All are using Revit 2017
We've just gone through the process of updating some of our titleblocks, and strangely, the text in the titleblock is showing different on computers running the 2 types of Windows software (Windows 7 & Windows 10).
When I say "showing differently", on the Windows 7 computers, the text will show within the text box as it has been typed in.
Whereas on the Windows 10 computers, its showing up as though someone has reduced the text box size, and letters & words are going to a 2nd line within the text box.
Example:
Windows 7 computer:
Testing 1234
Windows 10 computer:
Testing 12
34
Bear in mind this is exactly the same revit file, just opened on 2 different computers in the office. One running Windows 7 and one running Widows 10. Is this a known issue with Revit? I haven't come across it before.
The workaround we have come up with in the meantime is created 2 separate company template files - one for Windows 7 and one for Windows 10. As you could imagine this isn't ideal as we now have 2 templates to update evertime there is a modification required.
Any thoughts?
PS. We tried this exercise by opening Revit 2016 template on both Windows 7 & 10 computers and had no issues with the text. Not sure if it is a Windows 7/10 issue or just a coincidence. Any advice would be appreciated though.
Thanks in advance.
Edited on: Mon, May 15, 2017 at 2:05:34 AM
Mon, May 15, 2017 at 11:23:44 AM | Revit 2017 Text Displaying Differently - Windows 7 & 10
archigrafix
5 Stars: 4 Votes
Maybe this helps.
https://forums.autodesk.com/t5/revit-architecture-forum/revit-2016-to-2017-text-issue/td-p/6287119
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Mon, May 15, 2017 at 2:13:10 PM | Revit 2017 Text Displaying Differently - Windows 7 & 10
raja15
Archigraphix, Cheers for responding, I'm already aware of the text difference when upgrading to 2017, however the issue I'm having is within 2017 itself, just on computers running Windows 7 and Windows 10. I didn't think the text editor was to act differently in different windows software, in the same program (Revit 2017)
Mon, May 15, 2017 at 10:54:40 PM | Revit 2017 Text Displaying Differently - Windows 7 & 10
raja15
Just to follow up on this - we worked out why the text was behaving differently in Windows 7 & Windows 10. Turns out with Windows 10 they eliminated some fonts that were included in Windows 7. This is why they were showing up differently when opened on different computers.
Just something to be aware of I guess.
Tue, May 16, 2017 at 7:29:16 AM | Revit 2017 Text Displaying Differently - Windows 7 & 10
Glad you came back to explain.
Tue, May 16, 2017 at 9:52:27 AM | Revit 2017 Text Displaying Differently - Windows 7 & 10
blue442
blue442 Avatar
I'm curious, which fonts were removed?  Were you able to indenty them?
We have a copyright symbol that turns into a 'z' on some computers.  A while back i switched it to an ascci version of Arial and it fixed the problem.  Perhaps this is why it was a 'z' on some PCs.
Edited on: Tue, May 16, 2017 at 9:53:03 AM
Tue, May 16, 2017 at 5:28:48 PM | Revit 2017 Text Displaying Differently - Windows 7 & 10
raja15
The font was used for our company text in the titleblock and in Windows 7 it was called "AvantGarde Md BT Medium", however the same font had it's named changed in Windows 10 to "ITC Avant Garde Gothic" which has a series of different variations to the font.
I tested both these fonts on Windows 7 & 10 and noticed that they behave differently, for example how they display, how the letters are written, the white space between the letters, etc.
Hope this helps Blue442.
Wed, May 17, 2017 at 8:22:58 AM | Revit 2017 Text Displaying Differently - Windows 7 & 10
blue442
blue442 Avatar
Mostly a curiosity factor for myself.  But thank you for replying! I'm going to go back to an older file and see what font we were using for our copyright symbol.
Perhaps its name changed as well.
Edited on: Wed, May 17, 2017 at 8:24:11 AM
Revit 2017 in windows 10
Tue, Jul 26, 2016 at 12:57:10 PM
Window tags displaying differently from schedule
Tue, May 25, 2010 at 9:25:35 AM
Revit 2017 - "An unrecoverable error has occurred..."
Tue, Nov 15, 2016 at 1:29:21 AM
Revit Architecture 2010 thumbnails not displaying
Tue, Dec 28, 2010 at 1:59:06 PM
windows in elevation and 3d not displaying correctly
Thu, Oct 6, 2016 at 9:15:31 AM
Page generation time: 2.0485
