Forums >> Revit Building >> Technical Support >> elevation mark stacks text
Tue, May 9, 2017 at 2:36:22 PM | elevation mark stacks text
Warchitect
4 Stars: 5 Votes
How do I get the elevation bullet to NOT stack the text. so the picture has only two lines of text, name of level, and below that the height.
I want to add some info, but it starts to stack the text. see pic.
Tue, May 9, 2017 at 11:38:59 PM | elevation mark stacks text
Elnazer2
4 Stars: 5 Votes
if i understood you right you need to have all the data on the same line , so you need to extend the label in the level head family used in the type
View Name showing up in Elevation Tag
Wed, Feb 29, 2012 at 6:53:36 PM
Elevation Tag Mark (the circle) does not filter
Tue, Oct 16, 2012 at 1:55:49 PM
Elevation in MEP Wrong
Wed, Dec 30, 2009 at 1:59:39 PM
Spot Elevation Text
Tue, Mar 8, 2011 at 7:45:39 PM
Blue ? ( question mark) shared parameters [ 1 2 ]
Mon, Jan 17, 2011 at 1:17:42 AM
21
Page generation time: 0.7005
