22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> Sloped floor divided into parts - R2015. R2016
148 Posts No Rating |
Greetings.
I am trying to create a sloped floor slab using Split Lines and Modify Sub Elements, then use Parts to identify multiple finishes. Does Revit allow this?
Ian
Ian Shafer
Principal Consultant
True North S&F Consultants |
Split line and split face are two different tools.
Split line: allows you to add linear edges and to split the existing face of a floor into smaller sub-regions. Then with a variable thickness layer, the top face of the roof or floor can slope, and the bottom stays in a horizontal plane, creating a variable thickness floor.
Split face: allows you to modify the face material of elements.
WW
I appreciate your response and the definitions, but perhaps you missed my question.
Can I use parts to define multiple materials on a floor slab and still have the functionality to warp the slab using modify subelements (i.e. split line and add point)?
I am finding that once I've modified the subelements, I no longer have the option to create parts - if I create parts 1st, then I cannot access the modify subelements. Perhaps this is a limitation of Revit 2016 ...
Ian Shafer
I don't think you understand FLAT. Read this.
yOU HAVE THE ANSWER IN YOUR QUESTION: YOU CAN NOT DO BOTH THINGS
Thank you both for your kind and supportive answers ...
Ian Shafer
Dividing an external wall into different parts per floor |
Fri, May 12, 2017 at 3:46:57 PM
Sloped floor |
Thu, May 29, 2008 at 5:22:07 PM
add ins go to r2014 and wont load to r2015 |
Fri, May 2, 2014 at 2:38:47 PM
Revit 2012 - Parts won't divide |
Tue, Mar 18, 2014 at 3:37:43 PM
Sloped railing on sloped floor/ramp |
Tue, Dec 9, 2008 at 9:25:00 PM
