Forums >> Revit Building >> Technical Support >> How i can change the level with out move the building
Sat, Apr 29, 2017 at 5:41:51 AM | How i can change the level with out move the building
cgvuviet
Hi,
Good day,
I am a newbie for this. I have a issue for this case, please give me a hand.
I show my problems in the image below.
Thank you,
Regards
Sat, Apr 29, 2017 at 8:03:05 AM | How i can change the level with out move the building
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
So which is at the right level? The house or the contours?If the contours are corrrect then you need change the level heights in your house to bring it up to sit at the correct height.If the house is correct then just select the toposurface and lower it down until the levels are at the correct height.
Changing level height values while keeping building in place? [ 1 2 ]
Mon, Apr 13, 2015 at 1:47:48 AM
18
Elevation change of a portion of the building
Wed, Apr 27, 2011 at 10:45:35 AM
Level trouble - Level Constraints
Tue, Jul 13, 2010 at 9:44:54 AM
Move objects with level change
Mon, Sep 12, 2005 at 10:11:16 PM
changing multiple level heights
Wed, Oct 31, 2012 at 9:54:11 AM
Page generation time: 1.8519
