Forums >> Revit Building >> Technical Support >> All finish materials are grayed out in both Shaded and Consistent Colors View
Thu, Apr 27, 2017 at 7:05:52 AM | All finish materials are grayed out in both Shaded and Consistent Colors View
qtd690
The entire time I was developing the interiors package on this project, I was able to see the colors of the proposed materials with Consistent Colors view.  Now, a few months later, when I have to present to the client, all finishes are grayed out regardless of graphics view setting(Shaded or Consistent Colors).  The patterns (as defined in at the MATERIAL level) are showing up and accurate. I've read previous threads regarding similar issues, and the first response is, "you didn't set up your materials accurately"; however, just a few months ago, as I was developing the theory, everything was fine, not to mention, i've used these materials time and time again on several projects with no issue.
1. I've doubled checked my materials and both the APPEARANCE and GRAPHICS on all finishes have been set up correctly - as mentioned before, they are frequently used.  I've enclosed graphics citing an example of the floor finishes for your reference.
2. I've played with COARSE, MEDIUM and FINE settings - no difference.
3. I've looked at the VISIBILITY/GRAPHICS settings to see if something was overridden...all settings are standard, no overrides, NO FILTERS.
4.  I've tried painting the accurate materials on finish surfaces - no change.
5.  I've looked at the SHADED and CONSISTENT color settings - all revit standard settings, no overrides.
6. Phasing - shows PREVIOUS + NEW, revit standard, no overrides.  All finishes were developed under NEW CONSTRUCTION phase.
What have I not considered?
154312_16120_Issue_1.JPG154312_16120_Issue_2.JPG154312_16120_Issue_3.JPG154312_16120_Issue_4.JPG
Windows showing up gray in consistent colors view.
Tue, Apr 26, 2016 at 11:25:23 AM
13
Shading Brickwork
Tue, Jul 17, 2012 at 2:23:58 AM
Window Colors How to Adjust
Wed, Sep 25, 2013 at 12:53:35 PM
DWG import shaded colors
Sun, Apr 26, 2009 at 1:53:03 PM
topo depth
Wed, Nov 7, 2012 at 1:41:35 PM
Page generation time: 2.9625
