Forums >> General Discussion >> Revit Project Management >> Floor tag - elevation spot
Thu, Apr 27, 2017 at 6:46:34 AM | Floor tag - elevation spot
lukdab
Because there's no possibility to place spot elevation that shows only structure layer of floors on plans (is there?) I made floor tag with "elevation at top core" and "elevation at bottom core" labels but it adds 20 cm to the real value on several floors. Then I tried to add formula but it's not effective because you have to check if it shows extra centimeters or not on each floor.
Floors aren't offset from levels and they have only 1 cm of finish layer.
I work on 2017.
Anyone?
Thu, Apr 27, 2017 at 6:54:53 AM | Floor tag - elevation spot
If your floor only includes the structure layer, this works just fine.  We often used a seperate thin floor for finishes like tile.
Edited on: Thu, Apr 27, 2017 at 6:55:13 AM
Thu, Apr 27, 2017 at 7:01:03 AM | Floor tag - elevation spot
lukdab
I would make seperate floors but now it's too late I think.
And when you have more than one structure layer it also adds extra centimeters? 20?
Thu, Apr 27, 2017 at 7:10:04 AM | Floor tag - elevation spot
Never really too late for this.  You can edit your floor removing the finish layer and placing the floor lower than your finish floor level if needed.
Regarding the extra 20 cm - We would have to see more information on this.  Are you sure you have all the updates on 2017 installed?
Thu, Apr 27, 2017 at 7:20:09 AM | Floor tag - elevation spot
lukdab
<Are you sure you have all the updates on 2017 installed?>
Yes. I checked it because I found this: https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles/Foundation-families-in-Revit-show-faulty-dimension-paremeter-values.html
But nothing about floors.
System Families: Spot Elevation Tag
Thu, Jan 20, 2011 at 7:22:13 AM
Spot Elevation tag
Tue, May 6, 2014 at 12:41:09 PM
Spot elevation Tag and Insulation
Wed, Jun 11, 2014 at 10:00:27 AM
Spot dimension tags and thier relationship to ceilings
Wed, Feb 23, 2005 at 5:29:12 PM
Invert Elevation Vs. Spot Elevation
Mon, Apr 20, 2015 at 2:09:11 PM
Page generation time: 1.1615
