Forums >> Revit Building >> Technical Support >> Text being cut in the corner
Sun, Apr 23, 2017 at 6:35:46 AM | Text being cut in the corner
Dheena14asian
Hi,
I get a cut in the end of the text note. I tried changing all the settings. But nothing worked.
Can anyone please help me out.
Please see the attachement for better understanding.
Thanks
Sun, Apr 23, 2017 at 12:59:37 PM | Text being cut in the corner
It appears that your PDF writer may be substituting a different font.  Try a different one like 'cute', it is free on-line.
Sun, Apr 23, 2017 at 11:50:14 PM | Text being cut in the corner
Dheena14asian
Thanks @ WWHub.
But even in the printing output it is coming same as the PDF output! (Please see the attachment)
I used Ariel font style for Dimensions & Text notes.
The problem is only with text notes.
I tried changing text style but result still remains same.
Note : I printed directly from revit.
Edited on: Sun, Apr 23, 2017 at 11:53:37 PM
Mon, Apr 24, 2017 at 10:02:08 AM | Text being cut in the corner
First possibility - You don't say what Revit issue and what updates you have installed.  There are occasional bugs that are fixed with updates.
Second possibility is your printer driver and PDF driver.
What you show in your image has never come up as a problem with anyone else so that leads me to believe it is your system.
Section Cut
Fri, Nov 7, 2008 at 3:02:52 PM
Corner guards to snap to corner of wall
Tue, May 13, 2014 at 12:18:44 PM
Corner Window Wall Openings
Thu, May 27, 2010 at 1:22:42 PM
How to show a 'diagonal cross' when you cut timber beam/plate?
Wed, Oct 23, 2019 at 8:29:42 AM
corner windows
Tue, Jun 3, 2008 at 10:56:06 AM
Page generation time: 3.0376
