12 Users Online (10 Members):
Forums >> Revit Building >> Tips & Tricks >> Revit 2018 - Coordination Models and Printing to Vector
I thought I would post this here to help anyone that might run into the same issue.
In Revit 2018 if you use the new coordination model linking feature be sure to turn off coordination models in any of your plan views if you want to print as vector processing. I couldnt figure out why all of the sudden our sheets were printing using raster processing even though I set it to vector. I checked the "usual cause" and made sure there were no shading, shadows, gradients, sketchy lines, depth cueing, images or decals in the view. It turned out to be the navisworks coordination model we linked to our revit model. I had to go through our view templates and uncheck show coordination models.
Anyways, I hope this helps someone!
Erik
Vector Printing - Ceilings Disappear |
Wed, May 28, 2014 at 9:12:41 AM
Working with Coordination models |
Wed, Apr 8, 2020 at 11:01:18 AM
Losing wall tags when printing. |
Fri, Jan 20, 2017 at 9:07:39 AM
double printing Revit 2018 |
Mon, Jul 9, 2018 at 3:35:04 PM
Printing vector changes solid to hidden line, shaded areas don't show correctly |
Mon, Apr 20, 2015 at 10:56:21 AM
