Forums >> Revit Building >> Tips & Tricks >> Line weights of openings
Thu, Apr 20, 2017 at 11:05:43 AM | Line weights of openings
jimshunk
This has been wrecking my head of late. I have set my walls to a certain line weight in projection. Is there any way to change the lineweight around an opening. Changing the wall projection lineweight changes opening also, but I dont want them to both change. Its hard to explain but when the line weight is at a thicker weight, you can see the line below the cill of the opening. (see image). I have tried hiding the line in the family but to no avail. Anyone have a work around?
Thu, Apr 20, 2017 at 4:16:23 PM | Line weights of openings
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Try Manage Tab - Settings Section - Object Styles - Model Objects - Walls.Check the Walls Category Row against the Line Weight Projection & Cut Column.If not this, check visibility settings for that view.If not this, check if you have a view template applied..If not this, check if you have any over-ride settings applied to the view.
Line weights reverting to standard
Thu, Jan 6, 2011 at 7:10:38 AM
Revit Structure Questions Line Weights
Wed, Jan 16, 2013 at 3:33:32 PM
A Nice set of Revit Line Weights
Wed, Jun 20, 2007 at 8:47:36 PM
exterior elevations and line weights
Fri, Jul 20, 2007 at 12:06:07 PM
Line weights & detailing 2012
Thu, Jun 6, 2013 at 7:51:24 PM
Page generation time: 0.4713
