Forums >> Revit Building >> Technical Support >> convert stairs
Mon, Apr 17, 2017 at 3:18:49 PM | convert stairs
GLKIRK
Does anyone know how to make these stairs come to a common point/
I use 2013
Thanks,
Gary
Mon, Apr 17, 2017 at 9:58:50 PM | convert stairs
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Convert component stair to sketch, draw desired shape, use stepped underside surface and give 2, 3 feet for structural depth.
Tue, Apr 18, 2017 at 5:46:52 AM | convert stairs
GLKIRK
Thanks!
Along with this and a utube video, it works great!
Tue, Apr 18, 2017 at 8:03:00 AM | convert stairs
Don't you think the best design is that your porch slab sits on your brick walls.... actually extending over them slightly to create a drip?
Tue, Apr 18, 2017 at 8:36:29 AM | convert stairs
GLKIRK
Actually, here in VA, we use, what we call a "Rowlock" around the porch/stoop peremiter like this photo.
And/but I did not draw that.
I wanted to be clear in showing that the cantilever in the beams, because of where the columns are, did not pass code.
Thanks!
Tue, Apr 18, 2017 at 8:47:28 AM | convert stairs
Here, that detail doesn't work.   Because water gets between the brick and the slab, freezes and expands blowing out the brick.
I just didn't like how the steps met the wall.  The rowlock would help except when I see that detail down there, typically there is a brick pier at the ends of the step and the concrete steps flow into the concrete stoop.  You never step on the brick.
CONVERT RHINO TO REVIT
Thu, Feb 13, 2020 at 5:10:11 AM
Wrapping stairs
Thu, Aug 12, 2010 at 5:27:02 PM
Handrails at Curved Stairs
Mon, Sep 1, 2008 at 1:43:04 PM
How do you convert massings into floors, walls and roofs??
Thu, Jul 16, 2009 at 4:48:55 PM
stairs not dotted above
Fri, Feb 17, 2012 at 1:44:46 PM
Page generation time: 0.4519
