13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Floor and Ceiling Surface Pattern not showing in some 3D views
0 Posts No Rating |
I am having a problem with showing floor and ceiling surface patterns in 3D perspective views. They will show up in some views and not in others. In the views that arent showing up, if I zoom in they will show up but when I zoom out and print they do not show up. Im not sure how I can fix this. Any help would be great!
Textures at an oblique angle and small scale are typically not displayed.
0 Posts No Rating |
Is there anyway to get around that, and get them to display?
Think about this a little. Because of the oblique angle, the pattern is so tight that the lines become a solid black. Rather than showing that, Revit eleminates it. If you stand beside a brick wall and sight down it, you will never see the brick pattern.
Sloped Ceiling Surface Pattern Not Visibile |
Sun, Jun 26, 2016 at 7:21:36 PM
Floor pattern not showing up when the pattern is model pattern |
Fri, Nov 3, 2023 at 9:11:59 PM
Hiding Surface Pattern For Specific Wall Material |
Thu, Feb 21, 2008 at 10:47:29 AM
Surface Pattern on Modified Floor - No Skewing for Floor Plans |
Mon, Sep 12, 2016 at 7:45:11 PM
Ceiling Views not showing |
Tue, Apr 27, 2010 at 1:08:35 PM
