16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Building Elevations and Date/Time label
33 Posts No Rating |
Hello dear friends
A couple of more questions for you, Revit wisemen
First, How can I make Building Elevation signs not appear on sheets? Is there a way to disable the signs appearance entirely (not just per view)?
Edit: Figured out the second one myself thanks anyway
Much obliged
Post edited on 2006-05-23 07:24:45
Hi. i dont know a way to hide them from all views but in every view if u press vv and select annotation categories and then unclick elevation. about the date and time, i dont know since it does not appear on my prints, only if i print to pdf or print to file.
Hope this helps
----------------------------------- Golf anyone????? |
Thank you
But I'm looking for a more permanent way to hide them...
set their status in your template files that you use to start new drawings
HTH
Post edited on 2006-05-23 07:54:03
Format Label Date/ Time Stamp [ 1 2 ] |
Thu, Oct 22, 2020 at 12:22:53 PM
21
date only label |
Fri, Sep 18, 2015 at 9:40:28 AM
Dependent Date-Label |
Mon, May 13, 2013 at 2:23:04 AM
Date stamp |
Wed, Feb 15, 2006 at 4:40:45 PM
Title Block - How to create a new label? |
Fri, Apr 20, 2012 at 10:51:03 AM
