23 Users Online (21 Members):
Forums >> Revit Building >> Technical Support >> typical 3d views
We are working for a national retail comonay and i have families of all the fixtures. i have compiled a fixture sheet of 3d iso drawings using the selection box tools. i added my few call outs for each fixture. Now i want to pass this on to my coworkers as a standard sheet. i tried linking the bim, but i loose the sheet setup. Any suggestions on how i can use this sheet a 100 times this year?
You can only put these views in your template and set up the sheet there. You can also put this 3D project file in your library and they can load view from that into their projects.
Thank you again for the advise. I decided to create a seperate file that has everything layed out. The user will just have to update the TB and delete/turn off the details not needed. This file is linked to the template file so it shows up in the sheet list
Typical Floor as a Linked Revit File |
Fri, Aug 11, 2006 at 10:35:25 AM
Typical details |
Wed, Apr 14, 2010 at 1:11:59 PM
Custom Library - Typical Details |
Fri, Jun 24, 2011 at 1:10:55 PM
Typical Detail sheets on my first revit project |
Mon, Feb 8, 2010 at 9:22:07 AM
Typical Details |
Mon, Mar 26, 2012 at 4:55:56 PM
