9 Users Online (7 Members):
Forums >> Revit Structure >> Tips & Tricks >> Steel Structure Object Style
Hello,
I have a problem with the visibility settings in revit 2016. I have to built a steel structure with 20 different welded beams.
These beams are subcategorized in "structural framing". So, in the plan view all the beams are of the same color. No matter if i change the material (dublicate steel material with different color and align them to the different sections), no change in plan view!!!
I also created a subcategory object style under "structural framing" but i cant align it to to the beams.
The main problem is that i need to export this file to an autocad file, so the different color or layer in every steel section of major importance!
Thank you in advance.
There are a few ways you can achieve this, but they are all hacks/workarounds
#1. Create a Symbolic line in the family with different colours. You can use on/off instance parameters or you will need to create 20 seperate families though, one for each beam type
#2. Use filters and a parameter value. You could add a shared parameter, or use one of the family parameters (could use beam size if they are all different)
#3. (Assuming you are showing the beams as single lines) You can use the linework tool to override graphics
Hey Jessa,
Yours points were relevant and informative.
Steel Structure |
Fri, Mar 11, 2005 at 1:39:35 PM
Detail Component Object Style? |
Fri, Apr 9, 2010 at 10:01:48 AM
revit steel questions |
Mon, Apr 6, 2015 at 9:27:20 AM
True plan view of sloped steel? |
Mon, Feb 27, 2017 at 9:31:22 AM
14
OBJECT STYLE ISSUE |
Fri, Jan 30, 2015 at 10:34:36 AM
