Forums >> Revit Building >> Technical Support >> Vertical Offset, Polar Array
Tue, Mar 21, 2017 at 3:04:39 PM | Vertical Offset, Polar Array
mreddrick1333
Hello! Trying to create a family that uses a polar (radial) array, but I want each instance to be slightly higher than the next. Is this possible-- can you add a vertical offset to a polar array?
Polar Array - How to constrain the center location?
Tue, Nov 19, 2013 at 2:14:44 PM
Is Solution to Creating a Parametric Polar Array?
Tue, Oct 22, 2013 at 8:40:06 PM
how to creat a doom roof
Fri, Sep 5, 2008 at 4:38:27 AM
Parametric Array Constraints
Tue, Jul 2, 2019 at 7:00:45 AM
Array Arc with an offset from centre
Mon, Jan 7, 2013 at 7:47:01 AM
Page generation time: 0.2475
