12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> Detail Elements Extending Through Walls
0 Posts No Rating |
Hi All
Using REVIT 2017.
I had a question for the Revit gods. I am using Detail Items to show landscaping. The problem is that when a detail item is placed close to a wall, the detail item does not stop at the wall and I end up with the parts of the tree (for example) inside the building.
See attached image. I have tried a couple of different approaches using a filled region to mask the area and then changing the order, but this doesn't really work.
Any thoughts on how to stop this?
Thanks!
Sorry - detail items are 2D and they lay overtop of all model elements. You need a different process.
Neo-Tudor Timber Detail |
Tue, Feb 24, 2009 at 3:52:11 PM
How to maintain wall height when using Roof by Footprint and extending roof... |
Thu, May 18, 2017 at 4:50:11 AM
Pin Detail elements to move with Nearby Walls etc |
Fri, Aug 13, 2010 at 7:12:19 PM
Roof Interference with Walls |
Tue, Mar 18, 2008 at 6:43:38 PM
Massing Question - Extending floors into wall core |
Tue, Mar 4, 2008 at 10:27:59 AM
