Forums >> Revit Building >> Technical Support >> Stair tags
Tue, Oct 21, 2003 at 10:10:19 AM | Stair tags
camdogb
Is there a way to reduce the text (DN and UP symbols) for stairs?
Tue, Oct 21, 2003 at 1:04:50 PM | RE: Stair tags
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
Not sure if you can...I haven't found a way. You can turn off the "UP" and "DOWN" text in the visibility settings for stairs and retype it with the text tool. This will allow you to change the size. However, it would be nice to not have to use workarounds like that. I will continue to check on modifying the stair label and get back to you on whether or not this is possible.
Hiroshi Jacobs
Wed, Oct 22, 2003 at 1:27:57 PM | RE: Stair tags
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
Final answer...there is currently no way to edit the up and down labels on stairs. You'll have to use a work around at this point
Wed, Oct 22, 2003 at 1:34:29 PM | RE: Stair tags
camdogb
thanks for doing so much research. i'll apply text notes like you originally suggested
Wed, Oct 22, 2003 at 1:48:27 PM | RE: Stair tags
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
not a problem!
Hiroshi Jacobs
Can not swap out one stair family for another
Thu, Sep 19, 2013 at 12:24:19 PM
How can I create a split stair without multiple and separate stair components?
Tue, Jan 5, 2016 at 5:32:53 AM
Stair Nosing
Fri, Dec 2, 2016 at 2:01:57 PM
Simple Stair Nosing error
Thu, Mar 5, 2015 at 9:15:24 PM
Stair Showing Below Mezz Slab
Fri, Jan 27, 2012 at 8:21:10 AM
Page generation time: 1.8661
