Forums >> Community >> The Studio >> Piranesi & Revit
Mon, May 22, 2006 at 7:37:05 PM | Piranesi & Revit
jojo150
I am looking into purchasing Piranesi to enhance our 3D images and was wondering if anyone was actualy using it on Revit based models. Is object material maintained in the file translation? Any possitive & negative feedback welcome. Thanks Jo Jo Post edited on 2006-05-22 19:37:56
Tue, May 23, 2006 at 1:51:02 AM | RE: Piranesi & Revit
gregmeurer
4.5 Stars: 9 Votes
Never used Piranesi, but I have imported the project into 3d maxx and it seemed to work ok. Some of the materials cross over but most do not. Any lights that I had did not cross over either.
Tue, May 30, 2006 at 10:28:39 AM | RE: Piranesi & Revit
pepsiqueen
pepsiqueen Avatar
We started using piranesi last month; While it seems to work well with Sketchup, It would be even better if it could work well with revit. I was told that for revit materials and depth information to transfer to piranesi well you first had to take the model into Viz, unfortulately I don't have access to Viz. Piranesi is a great program though, you can take a blank Sketchup model and have a good looking rendered image really fast. I have tried exporting the revit file to 3d dwf and autocad, neither worked anywhere near well enough. I also tried revit > 3d autocad > sketchup> piranesi. this would work only if you spend some time in sketchup cleaning things up. I have searched the internet high and low for info on how to get revit working better with piranesi; but have not had much luck.
Thu, Jun 22, 2006 at 3:39:44 PM | RE: Piranesi & Revit
boo2u20
I know piranesi can handle dxf & dwg files, try exporting your revit model to cad, setting up the view, and then opening the dxf in piranesi. p.s. - funny to find you on the revit forum, hope things are going well since rwu! ~becky
Thu, Jun 22, 2006 at 5:36:35 PM | RE: Piranesi & Revit
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
check out the augi forums i know a few people have been using revit and piranesi there...
Thu, Jun 29, 2006 at 6:26:29 PM | RE: Piranesi & Revit
DFHammond
I have come accross this news item on the Piranesi Web site. It states that Accurender 4 now support s Piranesi. Does this mean that we should now be able to export an *.epix fie directly from Revit? I have just purchased Piranesi 4 so I am keen for this function to be available. see link http://www.informatix.co.uk/news.shtml#accu
Thu, Jun 29, 2006 at 6:50:48 PM | RE: Piranesi & Revit
guymessick
Our method of using Revit with Piranesi is to convert to .dwg, bring into Sketchup, then Sketchup into Piranesi directly. There is a lot one can do within this format, and we are shaping a process around it, but for now, works great. Guy Messick Director of Design Technology TLCD Architecture
Thu, Jun 29, 2006 at 7:54:10 PM | RE: Piranesi & Revit
coreed
coreed Avatar
4 Stars: 16 Votes
if they upgrade Revit to Accurender 4 and 4 has that support for Piranesi 4. then this will probably mean that we could write .epix files directly form Revit. which would be fantastic lets keep our fingers crossed
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Sun, Jul 2, 2006 at 10:43:04 AM | RE: Piranesi & Revit
scooter101
I am just looking at the Piranesi web site. http://www.informatix.co.uk/piranesi/index.shtml They have a 30 day trial. Why don't you do the trial and report back to us how and if it translates drawings.
Revit 2008 compatible with piranesi 5???
Mon, May 12, 2008 at 9:57:49 PM
Revit and Piranesi
Wed, Mar 30, 2005 at 1:56:42 PM
not render in revit, 3dmax & viz
Fri, Apr 17, 2009 at 4:29:23 AM
Rendering in Revit
Fri, Apr 17, 2009 at 4:32:29 AM
11
Editing & Drafting with floor levels Revit 2012
Fri, May 3, 2013 at 8:05:58 AM
Page generation time: 1.3461
