Forums >> Revit Building >> Tips & Tricks >> Complex line styles
Wed, Mar 15, 2017 at 11:46:43 PM | Complex line styles
Tinsmith2
My little problem is complex line styles
I have been using AutoCAD from the DOS ages, R10, and up to 2014. Moving to Revit 2013, a delight to be frank.
Recently I was asked to build a template for a Revit 2013 Template. Not too hard usually with AutoCAD but I have found a problem with making a complex line styles with line styles. We are dealing with water, gray, black, hot, cold, gas etc.
I have read as many of the posts in this forum and found quite a few of the similar lines, but I cannot get centre, phantom, long dash, triple dash etc.
Does anyone have a solution for this?? i have an image of what I am try to make,
Thu, Mar 16, 2017 at 7:37:12 AM | Complex line styles
Linestyles in Revit are only lines, they never contain letters or symbols.  "centre, phantom, long dash, triple dash"  are never a problem, center is already a default.  Just follow the HELP instructions.
Creating lines with symbols or letters requires a line-based family such as this one.  I think there are better ones if you search.
Removing Line Styles
Mon, May 8, 2017 at 2:21:04 PM
Associating Line styles with patterns
Tue, Sep 18, 2012 at 11:30:05 AM
Deleting Line Styles
Tue, Aug 5, 2014 at 2:57:29 PM
Line styles
Sun, Jun 3, 2018 at 8:27:34 AM
Line Styles Adjusting with Wall Hidden Lines?
Mon, Mar 12, 2018 at 12:58:29 PM
Page generation time: 0.9098
