Forums >> Revit Building >> Technical Support >> Perspective in sheets
Mon, May 22, 2006 at 9:00:54 AM | Perspective in sheets
Steiner
Hello friends... I have a slight problem with Perspective views... Whenever I drag'em into a sheet, they always appear to be too small... How can I make them show bigger in sheets?
Mon, May 22, 2006 at 11:29:22 AM | RE: Perspective in sheets
Dgodfrey
4 Stars: 4 Votes
You can either set the render image size in the properties box of that view or once you've inserted the view, activate it and stretch the crop box.
Mon, May 22, 2006 at 11:34:02 AM | RE: Perspective in sheets
spevans
When you are still in the 3D view click on the edge of view. Then on you option bar the size with appear and just change in. see attached image.
Perspective Problem
Fri, Jun 26, 2009 at 12:13:43 PM
Wishlist - Default perspective 3d view
Fri, May 2, 2014 at 9:31:09 AM
Perspective
Wed, May 21, 2008 at 6:20:57 AM
Moving Objects in 3d Perspective View
Wed, Jul 27, 2016 at 3:52:14 PM
perspective view
Thu, Feb 7, 2013 at 1:47:34 PM
Page generation time: 0.5002
