Forums >> Revit Building >> Technical Support >> Array on a Parametric Face
Tue, Mar 7, 2017 at 5:09:10 PM | Array on a Parametric Face
efflandj
Alright Revit wizards, here's a puzzle for you. I am trying to add a parametric array to a corner cupboard annotating where the shelves are inside. Because it is on a 45° plane, I cannot use symbolic lines and must use model lines (I think). I can get one line to flex just fine (see attached family). However, every time I try to array said line, the parameters and constraints break association and the arrayed lines stay fixed to where they were first created. I have tried an array of model lines created within the original family as well as an array of a model line family nested within. As a work around, I tried to create the array in the nested family before loading it into the cupboard family, but that array also breaks constraints which work just fine on a single line. I have also tried to create the model line family as a face based family, a level based family, and another casework family. Nothing seems to work... I've been wrestling with this for 3 days now and am just about ready to give up.
Revit 2016
Any help would be greatly appreciated.
Parametric Arrays
Fri, Feb 5, 2010 at 3:19:22 AM
arraying a face based family around a curved face
Thu, Oct 2, 2008 at 4:31:50 AM
Centering a parametric array in a family - RAC 2009
Thu, Jul 16, 2009 at 12:10:04 PM
Parametric Radial Array
Wed, Dec 14, 2011 at 1:39:23 AM
Array Parametric in Family
Tue, Nov 25, 2008 at 1:54:57 PM
Page generation time: 1.2954
