15 Users Online (13 Members):
Forums >> Revit Structure >> Technical Support >> Copy array of cut beam
Hi there,
If I place a beam representing a joist spanning 2 walls, I can cut each end of the beam to an angle by use of a reference plane where I want to cut.
My problem is, if I now make a copy, or an array from that beam, none of the copies have the cut applied to them. The copies revert back to the beams origonal profile.
Can I lock the cut in, before making my copies in some way?
Kind regards
gary
You can't do it. I ended up adding a void cut (simple void family rather than in-place) applied to each end then arraying those together.
Thank's for letting me know. I can put that bone down now :-)
Copy/array an extrusion in the "depth" direction |
Thu, Sep 9, 2010 at 11:57:10 AM
Beam Family Array Formula Help |
Thu, Oct 23, 2014 at 9:40:34 AM
Use Nested Void Family to Cut Host? |
Sat, May 28, 2011 at 10:39:48 AM
Cut a sloped beam |
Fri, May 11, 2012 at 3:48:19 AM
how can I array along spline? [ 1 2 ] |
Fri, Nov 28, 2008 at 7:07:32 AM
19
