Forums >> Revit Building >> Technical Support >> Revit 2017 shuts when either opening, saving or closing a window.
Thu, Mar 2, 2017 at 4:09:55 AM | Revit 2017 shuts when either opening, saving or closing a window.
Calman1993
5 Stars: 2 Votes
Hi, I am in need of some help, the problem i am having is that on most of my revit drawings when i either save a job or close the window revit pops up with a message and closes, the message says;
Autodest Revit has stopped working
A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.
I dont believe that the RVT files are broken, or over complicated that it would make revit shut down everytime.
Do any of you guys have a solution?
Many Thanks
Calman
Thu, Mar 2, 2017 at 7:34:46 AM | Revit 2017 shuts when either opening, saving or closing a window.
Some people may be able to help if you provide information we should not have to ask for.
  • Revit issue and updates
  • Your equipment / operating system - available disk storage
  • Your file size
  • Are you closing from tiled windows?
Mon, Mar 6, 2017 at 3:08:35 AM | Revit 2017 shuts when either opening, saving or closing a window.
Calman1993
5 Stars: 2 Votes
  • Revit issue and updates Not sure but i am up to date according to the autodesk manager.
  • Your equipment / operating system - available disk storage Windows 10 we are working from a network with 561gb free storage
  • Your file size Its all files so cant give you all the sizes but range from 1mb - 23mb.
  • Are you closing from tiled windows? Yes
I hope this helps a little, im not very computer technical, I have a feeling it is a Windows 10 thing as this never happened on Windows 7.
Mon, Mar 6, 2017 at 10:24:44 AM | Revit 2017 shuts when either opening, saving or closing a window.
First - get up to date.
You say you are working on a network.
  • Are you using work sharing?
  • Is this a local file being saved on a network?  (Should not save lovcals on network)
  • If worksharing, you have to give Revit time to update the central before closing your local.
  • Closing files from tiled windows results in a very big file size.   It is always best to close all windows but one before saving.   We actually closed from a very small view that described the project.
Revit shuts down without warning?
Tue, Jun 3, 2008 at 3:55:37 AM
Bi-Fold doors parametrics for opening and closing 3d panels by percentage?
Wed, May 16, 2012 at 10:14:45 PM
Open Family Editor in Floor Plan View by Default
Thu, Jan 12, 2017 at 6:20:20 PM
Window Head / Opening Cut
Mon, Feb 10, 2014 at 7:30:59 AM
window opening
Mon, Aug 24, 2009 at 8:03:18 AM
Page generation time: 3.0409
