16 Users Online (14 Members):
Forums >> Revit Structure >> Technical Support >> Roof with non-parallel walls
0 Posts No Rating |
We are currently trying to accurately model a pitched roof on a building with 4 non-parallel walls. The roof has modelled but the ridge line is not level. We have tried changing the angles of the various pitches but to no avail. Please see attached screenshots. (Revit 2017)
Edited on: Tue, Feb 28, 2017 at 4:00:52 AM
Think about it! If the walls are not parallel and you want a flat ridge, either your slopes have to be warped or your eaves have to change. Model it with some c ardboard, you will see what happens.
0 Posts No Rating |
Modelling in place would indicate otherwise
You said the walls are not parallel. Did you miss-speak? Show us a plan because this does not make sense.
Perhaps you made up the difference with variable eave widths.
0 Posts No Rating |
No, I did not 'miss-speak', the walls are not parallel (the thread title would indicate...). I have attached the roof plan which accompanies the model-in-place
OK... This is simple geometry. If the roof ridge is level and the roof eave is level and the same distance from the wall face, then the roof slope distance has to be the same for the entire roof! The width of your roof changes. Shorten the hypotenuse (leg C) and both of the other legs have to get shorter!
So what do you want to adjust?
- The ridge elevation
- The eave elevation
- The roof overhang
- Warp the roof slope.
dimension parallel to roof plane |
Sun, Nov 4, 2012 at 3:56:11 PM
Shed Roof between non-parrallel walls |
Tue, Dec 2, 2008 at 7:02:36 PM
Parallel walls join geometry do not cut opening |
Fri, Jan 31, 2020 at 1:32:48 PM
Dimensioning Parallel Curves |
Thu, Aug 30, 2007 at 10:22:52 AM
Parallel walls locked in relation to one another? |
Thu, Apr 27, 2006 at 10:53:42 PM
