Forums >> Revit Building >> Technical Support >> Fixing a door frame, no matter(almost) the wall thickness
Fri, Feb 24, 2017 at 7:35:44 AM | Fixing a door frame, no matter(almost) the wall thickness
nick850c
Hi Revicity users,
I hope someone can help me with this problem.
I want to fix my door family so that the door frame wont change position when I flip the door.
For example I want the dimension between the inner wall and the door frame to be 60 cm - fixed, so the dimension between outer wall and door frame can be variable.
See the attached jpgs - the red lines symbolize that I want the frame to stay in the same place no matter if I flip or not, and the dimension (60cm) between inner wall and door frame always to be 60cm. So basically only the door swing needs to flip, I guess?
Hope someone can be of help :-)
Thanks.
///Nicky
Edited on: Fri, Feb 24, 2017 at 7:36:49 AM
Edited on: Fri, Feb 24, 2017 at 7:38:03 AM
Fri, Feb 24, 2017 at 8:56:08 AM | Fixing a door frame, no matter(almost) the wall thickness
CDWdavid
5 Stars: 5 Votes
You can create a parameter "Set-Back" as an instance parameter.
Unfortunately, you have to manuly change each of them.
WWHub, would you pls remove this?  Thanks!
Edited on: Fri, Feb 24, 2017 at 9:03:03 AM
Thu, Apr 6, 2017 at 3:41:43 AM | CDWdavid
nick850c
Quoting CDWdavid from 2017-02-24 08:56:21
You can create a parameter "Setback" as an instance parameter.
Unfortunately, you have to manually change each of them.
Edited on: Fri, Feb 24, 2017 at 9:04:58 AM"
Hi CDWdavid,
Sorry for my late reply.
Just wanted to say thanks for your input.
I found a solution by just using symbolic lines and adding a visibility parameter to each. So now I can just switch either interior or exterior door swing on/off - which is a simple fix.
Making door frame match Wall thickness..
Thu, Jul 20, 2006 at 6:12:46 PM
Control Position of Door Frame/Panel in Wall Thicker Than Door Frame
Thu, May 6, 2010 at 7:29:41 AM
Door Frame
Tue, Sep 28, 2004 at 5:58:51 PM
Revit 2013 - Window frame sweep with wall thickness
Wed, Nov 28, 2012 at 4:03:26 AM
Wall Thickness in Type Parameter
Fri, Jun 1, 2018 at 7:39:15 AM
Page generation time: 0.6006
