Forums >> Revit Building >> Technical Support >> Associated Parameters in Array Family
Thu, Feb 23, 2017 at 4:36:16 PM | Associated Parameters in Array Family
CDWdavid
5 Stars: 5 Votes
Hope that someone can help me on this question for array families.
If I have a rectangular filled region with instance parameters "Bar Length" and "Bar Width" in a family "Bar", then nested into another family "Path" with instance parameters "Length" and "Width".
In the family "Path", I made the "Bar Length" associated to "Length", "Bar Width" to "Width".
Now I loaded the "Path" into a project A. I'm able to control the length and width of that filled region in the project A.
However, if I try to aplly this in an array family, then I even cannot set up the associated parameters "Bar Length" and "Bar Width" in that array family.
Did I miss something?
Thanks for any input.
Fri, Feb 24, 2017 at 6:47:56 AM | Associated Parameters in Array Family
I don't believe you missed anything.  I don't believe we have ever been able to control parameters in nested array families.
There was a tutorial on nested families in arrays but the link is not working.  I will see if I can get our ADMIN to repair that.
Fri, Feb 24, 2017 at 7:27:42 AM | Associated Parameters in Array Family
marmiketin1
4.5 Stars: 10 Votes
Are you nesting the Path family into your array family or the Bar family into the array family? Are you arraying in a family or directly in the project file? If you want to have parameters associated through the nested families this needs to all be done within families. Also I find it better to always have your parameters set as type until you reach the final host family, there you can make all linked parameters either instance or type.
Fri, Feb 24, 2017 at 8:42:14 AM | Associated Parameters in Array Family
CDWdavid
5 Stars: 5 Votes
Thanks to both.
Resolved, when I have time, I will post the process here.
Thanks again!
Mon, Feb 27, 2017 at 8:44:36 AM | Associated Parameters in Array Family
CDWdavid
5 Stars: 5 Votes
Please see the attached POT, and the step by step explanation.
Parametric Array Constraints
Tue, Jul 2, 2019 at 7:00:45 AM
Polar Array - How to constrain the center location?
Tue, Nov 19, 2013 at 2:14:44 PM
Variable Length Family with Array Formula
Wed, Aug 8, 2012 at 9:56:46 AM
Editable nested family inside parametric array host family
Wed, May 19, 2021 at 8:05:22 AM
ARRAY INSIDE A FAMILY
Fri, Oct 12, 2007 at 12:41:17 AM
Page generation time: 2.5591
