12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> Spot Elevations - Random snapping.
Hi Reviteers,
Revit 2017.
When adding Spot Elevation tags (in plan-view), Revit shows a cross-hair which snaps to random points on my toposurface; sometimes snapping to the juncture between Subregions, other times snapping to the top of a wall when I need the toposurface elevation against the face of the wall.
Using the Tab-key doesn't work (I thought it would scroll through the different objects / instances...).
Has anyone found a way around this?
Cheers.
Revit finds edges. If you created a Pad to cut your topo at the outline of your building, you can tab selected that edge.
Revit will also find ponts anywhere on a topo surface. Maybe you have an incorrect setting.
Edited on: Tue, Feb 21, 2017 at 6:34:08 AM
Setting a manual height for Spot Elevations in plan |
Wed, May 27, 2015 at 8:03:11 AM
Random Elevations Not Printing |
Tue, May 20, 2014 at 9:02:54 AM
Spot elevations |
Fri, Jul 29, 2016 at 8:01:28 AM
Revit Spot Elevations, Rooms and Color Schemes Problem |
Mon, Jun 24, 2013 at 12:46:35 PM
Revit refusing to use Spot Elevations |
Mon, Oct 14, 2013 at 3:47:54 PM
13
