15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Attaching a gutter to a wall instead of a roof
Is it possible to attach a gutter to a wall instead of a roof? I have a project with 24" thick concrete walls, and a 36" thick concrete roof. The walls will be in place first, and the roof will span between the walls, sloping in one direction to the outside wall. If I just select the roof gutter in the Architectural tab, it will not allow me to attach it to the wall.
Thanks,
Use a wall sweep with a gutter profile. Otherwise you will need to use an in-place sweep.
You can set an offset for the gutter that should compensate for the wall. Just turn off the wall so you can pick the roof.
Thanks, I used the offset method. It was quick and easy. I'll keep the sweep option in mind for future use.
Gutter display on roof plan |
Mon, Jun 11, 2007 at 3:47:21 PM
Wall not attaching to roof |
Thu, Sep 18, 2008 at 12:58:01 AM
Gutter to extend when using join/unjoin roof |
Thu, Jul 2, 2009 at 8:40:03 PM
Adding a gutter |
Tue, Dec 15, 2009 at 5:06:50 PM
Curved roof tiles into gutter. |
Thu, Nov 13, 2014 at 3:57:54 PM
