Forums >> General Discussion >> Revit Project Management >> Revit 2015 to Navis 2017 Exports for Coordination
Mon, Feb 20, 2017 at 1:50:54 PM | Revit 2015 to Navis 2017 Exports for Coordination
Pikachu123
I am working with 1/2 dozen other designers, and we have to export a .nwc for coordniation 2-3 times a day. When i export to an .nwc a warning displays and displays, "cannot open [file_name] for writing" causing the export to fail. Troubleshooting it, i thought it was the Navis setting "close on load" toggle, and we should turn th  toggle off, but i didnt have any luck with that because only half of us are having this issue, and i would like to nip this in the bud before it becomes an absolute disaster spawned from free will. With everyone constantely updating, this snag is causing compounded problems of people not working with the most up-to-date files, and/or creating duplicate files and causing neccassary chaos/stress. Any assistance would be greatly appreciated, making 5 calls/emails each time to update a file is a little time consuming. Please and thank you.
P.S.- Navisworks setting screenshot attached.
Mon, Feb 20, 2017 at 2:10:43 PM | Revit 2015 to Navis 2017 Exports for Coordination
I'm sure you have a ton of memory and capacity on your machine but this platform still has some carried over limitations from the DOS days.  I have seen your kind of problems because the tmp file area seems to run out of room.  The fix for us was to run CCleaner and clear out those files.
Revit Arch & Navis Applied to $500SF-$1100SF Custom HOMES
Thu, Oct 16, 2014 at 11:29:28 AM
Navis from Revit 14
Mon, Jan 13, 2014 at 10:31:14 AM
Working with Coordination models
Wed, Apr 8, 2020 at 11:01:18 AM
Revit 2015 Download File?
Tue, Mar 17, 2020 at 6:11:19 AM
Navis export option from Revit - missing - how do I fix registry to sort?
Fri, Apr 23, 2010 at 4:28:56 PM
Page generation time: 1.4634
