19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Creating a Family
Hi guys!
I'm a absolutly new-comer in Revit. I try to create a family, which I can place in a concrete slab. For instance it is a ball-shaped element made of glass. Is it possible to replace the concrete at the position where my family element is? So that the family element works as a removal elemt and the volume of the concrete slab reduces by the volume of the ball-element?
thank you for your help in advance!
best
First item to address is family template. What did you use? As you describe this, the template should either be floor based or face based.
Because this is an unusual family, you will have to create both the solid and a seperate void form to cut the host. This is not an easy process for beginners so read the HELP and visit some youtube posts on this subject.
hi WWWHub,
thank you very much for your fast response. Okay, I think I will first of all try to create a floor based family.
Will let you know if I finished this and will come back after some Youtube tutorials.
best
Creating a family |
Wed, Apr 15, 2015 at 8:43:02 AM
Creating a Family with Multiple Components |
Mon, Dec 2, 2013 at 12:53:24 PM
Family Categories / Creating |
Thu, Dec 11, 2008 at 4:16:39 PM
Creating nested Family Parameters |
Fri, Jun 26, 2015 at 3:52:28 AM
Creating Labels for Family Objects |
Wed, Nov 21, 2012 at 9:29:11 AM
