Forums >> Revit Building >> Technical Support >> Graphical Wall Hatch Issue
Wed, Feb 8, 2017 at 10:04:52 AM | Graphical Wall Hatch Issue
JoshuaV
I'm using a solid wall hatch for new construction phase walls (overriden in phase management), and I noticed that the core of the wall hatch seems to be taking visual precedents over the thickness of the perimeter wall cut lines. The result is that I only get half the thickness of the line weights and a funky look at my wall intersections. I feel like I've had this issue before, but can't remember how I resolved it. Any idea? I tried searching around and couldn't find another thread about it.
Take a look at the attached screenshot. I moused over the one wall to highlight the portion of line not showing.
Sun, Feb 12, 2017 at 5:35:10 PM | Graphical Wall Hatch Issue
archigrafix
5 Stars: 4 Votes
Maybe the override can be done more simpler and with better control without using definitions on the phase? We invite you for instance to use Graphic Studio that is available on Autodesk Apps on a free trial and do these adjustments.
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Getting Cut Wall Hatch to move WITH the Wall
Fri, Aug 10, 2012 at 2:59:50 PM
Graphical Presentation
Mon, Dec 29, 2008 at 3:05:39 PM
Graphical Column Schedule
Mon, Dec 10, 2018 at 5:58:55 AM
walls wont hatch in plan...?
Wed, Mar 27, 2013 at 3:22:00 PM
how to fix distorted hatch pattern on wall?
Fri, Jan 18, 2013 at 6:18:29 PM
Page generation time: 1.1093
