Forums >> Revit Building >> Technical Support >> Wall joint not working !
Sun, Feb 5, 2017 at 12:05:35 PM | Wall joint not working !
Dheena14asian
Hello guys,
I am trying to make a proper joint in the intersection area. But it does not resulting as expected.
Please help me out. And find out the details in the attached pictures.
Thank you
Sun, Feb 5, 2017 at 12:26:14 PM | Wall joint not working !
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Read up on: wall layer wrapping:https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/Revit-Model/files/GUID-69B6DC75-56A9-4F35-BE24-80048360E2BB-htm.html
Wall join cleanup:https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/Revit-Model/files/GUID-130A65BC-8C57-4C31-8C07-F96041771539-htm.htmlWall Core Boundary
Fri, Feb 10, 2017 at 5:08:33 AM | Wall joint not working !
Dheena14asian
Thanks to Beaucoupnice.
How do you hide the joint lines between different wall types?
Fri, Nov 16, 2007 at 8:16:34 AM
Creating an expansion joint family
Sat, May 2, 2009 at 10:57:03 AM
newly created wall footing won't joint
Mon, Nov 3, 2008 at 10:02:11 AM
Curtain Wall Issues_Edge Joint
Fri, Jun 1, 2007 at 1:36:41 PM
wall joint in plan view
Wed, Feb 16, 2005 at 10:50:01 AM
Page generation time: 1.8309
