Forums >> Revit Building >> Technical Support >> double acting door family swing angle parameter
Thu, Feb 2, 2017 at 8:32:45 AM | double acting door family swing angle parameter
ledgewood33
I created a double acting door family with a swing angle parameter that allows the user to change the angle of the symbolic lines that represent the door swing in plan view. with the double acting aspect I have symbolic lines that represent the door swing in plan on each side of the wall. for some reason I cannot change the swing angle greater than 88 degrees. when I choose to go greater the family breaks and I get several error messages. I am attaching the family for your review. the family was originally built in revit 2015
Thu, Feb 2, 2017 at 8:41:55 AM | double acting door family swing angle parameter
Read the Variable Angle Door Swing breaks at 150° post listed in similar threads below.
Fri, Feb 3, 2017 at 10:22:58 PM | double acting door family swing angle parameter
Bartholomew
5 Stars: 2 Votes
May I suggest you pull your dimensions from Ref. Planes - not the symboloic linework itself - and have your symbolic line work aligned, locked and dimensioned from those/to those Ref Planes.
Edited on: Fri, Feb 3, 2017 at 10:23:42 PM
creat double door w/ adjustable swing
Mon, Apr 27, 2015 at 1:30:05 PM
Nested Door Family w/ Adjustable 3D Swing Angle
Tue, Jul 31, 2007 at 5:34:20 PM
3D Swing parameter!! Help!!
Sat, May 11, 2013 at 7:03:34 AM
Fri, Sep 12, 2014 at 4:39:10 AM
Fully Parametric door with 45 angle swing
Wed, Mar 26, 2025 at 11:13:10 PM
Page generation time: 0.8350
