Forums >> General Discussion >> Revit Project Management >> map autocad shx fonts to Revit
Wed, Feb 1, 2017 at 7:55:56 PM | map autocad shx fonts to Revit
SteveB
3.5 Stars: 5 Votes
I am trying to map autocad shx fonts to Revit.   The help file...   http://help.autodesk.com/view/RVT/2017/ENU/?guid=GUID-87119589-ADE4-41AD-A796-3EB3C1DDDA82  ...says to find this file:   "shxfontmap.txt "
I can't find it anywhere.  The path they reference it being located at ...
"AutoCAD SHX fonts are stored in the following location: C:\Program Files\Autodesk\AutoCAD <release>\Fonts+
... does not exist.   I have searched the entire computer for "shxfontmap.txt".  Nothing.
Thu, Feb 2, 2017 at 6:26:25 AM | map autocad shx fonts to Revit
NO.... The mapping is done in the RVT files depending on your issue.
To map fonts, edit shxfontmap.txt using a text editor. This file resides in the following location: %APPDATA%\Autodesk\Revit\Revit 2017
Fri, Feb 3, 2017 at 3:57:52 AM | map autocad shx fonts to Revit
archigrafix
5 Stars: 4 Votes
For some reason here is:
%APPDATA%\Autodesk\Revit\Autodesk Revit 2017
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
shx fonts please help
Sat, Jun 17, 2006 at 10:51:57 PM
.shx fonts
Fri, May 29, 2009 at 10:36:25 AM
Revit fonts that match AutoCad .shx fonts
Thu, Jun 14, 2007 at 3:52:14 PM
export ttf to shx fonts
Wed, Apr 8, 2009 at 12:04:05 PM
Font mapping not working...
Mon, Sep 26, 2011 at 11:18:28 AM
Page generation time: 1.9339
