22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> Levels Line Length
105 Posts No Rating |
Revit 2017, OS10
Is there a way to make it so that elevations on oposite sides of the building do not have the same lenght of level lines extension. If you change the extension length of an elevation line(s) on the south side of the the building, then the North side reflects that same length change (same with east to west). Is there a way to unlink them so I can have the legths on oposite elevations be different?
Levels will behave like this in 3D extends. Either, manually click on 3D to change to 2D, or adjust the size of the crop region so it cuts the levels. They will switch automatically to 2D.
In eight years of using Revit I have never run into that. Thanks for the information.
line based family help (length) |
Wed, Aug 6, 2014 at 9:15:36 AM
Tag Area Boundary Line Length |
Wed, Feb 17, 2021 at 8:59:13 AM
How to make family length visible in project |
Tue, Nov 14, 2017 at 2:53:03 AM
Parametric Line Extension...array or repeating line or...? |
Mon, Jul 2, 2012 at 3:30:38 PM
Cannot edit wall length in Revit |
Sun, Jun 4, 2017 at 1:51:08 PM
