Forums >> Revit Building >> Technical Support >> Weird Winder Stair Geometry
Wed, Jan 25, 2017 at 7:41:12 AM | Weird Winder Stair Geometry
yigitti
Hello everyone,
I created a stair from component stair by changing it to sketch based. In plan view stair looks fine. But resulting 3D geometry looks really bad. Especially bottom surface of the stair....Do you have any idea why it is so?
..I saw in a youtube video that inequal radial riser lines might cause. So I checked it and everything looks ok there.
Wed, Jan 25, 2017 at 7:45:28 AM | Weird Winder Stair Geometry
marmiketin1
4.5 Stars: 10 Votes
try making the radial riser lines eqaul angle (30)
Wed, Jan 25, 2017 at 7:59:17 AM | Weird Winder Stair Geometry
yigitti
Thanks for the reply, but it didn' t work. I attached two screenshots showing the resulting geometry after I changed as you said.
Winder Stairs in 2013
Tue, May 8, 2012 at 12:49:31 PM
Monolithic winder stair
Thu, Aug 22, 2013 at 12:50:18 PM
How to achieve newell posts on winder stair
Tue, Jul 24, 2007 at 6:18:30 AM
partial wall miter below winder [ 1 2 ]
Sun, May 3, 2009 at 12:21:40 PM
20
stair with 2 winder -> railing
Wed, Sep 9, 2009 at 12:38:00 PM
Page generation time: 0.1270
