Forums >> Revit Building >> Technical Support >> Custom Stair Tread Profile vs. Default Tread Profile
Wed, Jan 25, 2017 at 6:44:00 AM | Custom Stair Tread Profile vs. Default Tread Profile
yigitti
Hi!
I made custom profiles for the stair that I'm working on. Everyting works fine in section views. But because it is a profile, it only sweeps along the edge of the stair I guess. But 'default' tread profile covers all the area. How can I achieve this with my customized profile? I attached the screenshots.
Default_Tread: It shows partially what I want to achieve in 3D. Tread covers all the winder stair areas.
Stair_Tread Profile: Undesired 3D which resulted because of the customized profile.
Any help is much appreciated.Thanks.
Tue, Apr 30, 2019 at 8:45:04 AM | Custom Stair Tread Profile vs. Default Tread Profile
rivnovo
I'm experiencing the same issue. Did you have any luck finding a solution?
Tue, Apr 30, 2019 at 8:54:08 AM | Custom Stair Tread Profile vs. Default Tread Profile
yigitti
Unfortunately not Sad
Tue, Apr 30, 2019 at 2:28:08 PM | Custom Stair Tread Profile vs. Default Tread Profile
CDWdavid
5 Stars: 5 Votes
First, you can open “Stair Nosing – Pan” in Families under “Profiles”. Modify it to any shape you like.
Then, see the attached picture, you can change the Nosing Profile to the name you just created.
Play with it. Just keep in mind that the nosing is placed along the front of the tread.
edit profile precast stair
Sun, Sep 18, 2016 at 1:54:07 PM
12
How to model a non-typical length stair tread for the top tread
Mon, Jan 25, 2016 at 1:55:19 PM
Stair - Cut Profile
Wed, Sep 14, 2011 at 1:36:18 AM
2015 use baluster per tread on stair (with no top rail?)
Thu, Sep 3, 2015 at 4:50:57 PM
Baluster per tread on curved stair
Thu, Apr 4, 2013 at 2:18:52 PM
Page generation time: 1.9705
