Forums >> Revit Building >> Technical Support >> cabinet inset disappears.
Mon, Jan 23, 2017 at 2:41:43 PM | cabinet inset disappears.
Warchitect
4 Stars: 5 Votes
I load this shaker style cabinet into my project, and it takes away the shaker panel inset. leaves me with a smooth panel. Ive tried to reload it, rename and reload it, everything. it loads fine into a new blank prject. but I can't seem to figure out when it does this for my actual project i need it in. see pic. also here is the file.
Mon, Jan 23, 2017 at 3:23:11 PM | cabinet inset disappears.
marmiketin1
4.5 Stars: 10 Votes
I havent opened the .rfa but I assume there is a parameter for turning the inset on or off which is default set to off. Check your properties and type properties when the family is loaded into the project.
Mon, Jan 23, 2017 at 3:33:37 PM | cabinet inset disappears.
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Works fine for me.  Purge the family right out of your project and reload it.
Mon, Jan 23, 2017 at 7:15:41 PM | cabinet inset disappears.
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
See picture.
library part adjusts without guided dims or reference planes
Sun, Dec 13, 2015 at 3:24:23 PM
How do I cut cabinet to host recessed light? Using Revit 2009
Thu, Apr 17, 2008 at 10:00:03 AM
Wall Type with inset coursing (Revit 2017)
Tue, Aug 15, 2017 at 10:02:46 AM
window with inset parameter
Thu, Jan 23, 2014 at 9:41:01 AM
One cabinet is dashed and the one on side of it is solid
Thu, Jun 24, 2010 at 8:53:22 AM
Page generation time: 1.2931
