Forums >> Revit Building >> Technical Support >> Material assigned to topo but still rendering in gray
Sun, Jan 22, 2017 at 11:30:56 PM | Material assigned to topo but still rendering in gray
bfrancis1982
Hi all
(revit 2015) I originally had no issues with this but changed computers (making sure all my objects and images reamined in the same file destinations when transferred). however now when i view in realistic or render my site the topography remains grey, even though i have assigned a material (see screenshot). I have checked my VG settings and there are no overrides in place to prevent viewing the grassed surface so am a bit lost.
Mon, Jan 23, 2017 at 10:57:36 AM | Material assigned to topo but still rendering in gray
Those are your render settings, what does your graphics tab say?
Also, phases?
Fri, Jan 27, 2017 at 7:53:01 PM | Material assigned to topo but still rendering in gray
bfrancis1982
i have a graded site region and an existing (2 diff phases) but they are both coming up grey my topo graphics tab is attached
Sat, Jan 28, 2017 at 10:05:04 AM | Material assigned to topo but still rendering in gray
Go back and look at your original image..... What kind of color do you think 255/255/255 gives you then look at the graphics tab in that first image.   You need a color and you need a fill pattern (probhably solid fill).
Steel material showing gray when rendering
Mon, Mar 16, 2015 at 1:39:01 PM
Rendering Problem.
Wed, Apr 9, 2008 at 5:13:16 PM
Topo material color not showing?
Thu, Nov 26, 2020 at 11:24:41 AM
Assigned a jpeg image to one material and other have it too
Fri, Jul 10, 2015 at 7:30:33 AM
Rendering coming out gray
Wed, Jul 19, 2006 at 5:49:21 PM
Page generation time: 0.3894
