Forums >> Revit Building >> Technical Support >> Hatching a rated floor
Mon, Jan 16, 2017 at 1:10:31 PM | Hatching a rated floor
BA3904
3 Stars: 2 Votes
I need to hatch a small area of my project that is a rated floor.  I need to do this only in my Code Review Plans, and since they are at a small scale, my detail level is Coarse.  I want to hatch this without showing the hatching for all of the other materials in the model.  Does anyone have any suggestions as to how I can acheive this?  I'm using Revit 2016.  Thanks.
Mon, Jan 16, 2017 at 3:24:54 PM | Hatching a rated floor
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Intelligent method would be to create a global parameter. Call it say "Floor Rating". Then create filters and tell them to hatch each room in accordance with what their parameters are populatd with.
Dumb method would be to just use a fill region and hatch the areas that are to be rated.
Tue, Jan 17, 2017 at 8:56:25 AM | Hatching a rated floor
BA3904
3 Stars: 2 Votes
Thank you, since it is such a small area, I opted for the dumb method.
Tue, Jan 17, 2017 at 12:45:07 PM | Hatching a rated floor
galen
1 Stars: 1 Votes
The semi-dumb method would be to put a elemant graphic overide on your floor, at least that way it will change in shape with the floor.
Align Fire Wall Hatching in Wall
Tue, Jul 3, 2012 at 7:07:43 AM
hatching line doesn't show in callout views
Thu, Jul 26, 2012 at 7:10:09 AM
Help with Hatching in a 3d famiy
Tue, Jun 8, 2010 at 3:48:23 AM
Fire Rated Walls Plan
Sat, Sep 8, 2012 at 11:31:19 PM
Topography and hatching in section / elevation
Sat, Sep 27, 2008 at 7:55:41 PM
Page generation time: 0.8308
