Forums >> Community >> The Studio >> Revit Rendering Problem - Black Quadrants
Mon, Jan 16, 2017 at 9:35:45 AM | Revit Rendering Problem - Black Quadrants
hferrari13
Good Morning Everyone,
When I attempt to print to a printer resolution of 600 DPI Revit returns a rendering with 1/4 of the image present and the rest is solid black, regardless of how long I let it render.  The attached photo is an example.  Any ideas on how to get a higher quality rendering without the black quadrants?  I seen a post on reducing the dimensions of the image and I made it less than 6" in both length and width to no avail.   Thank you everyone for your help.
Mon, Mar 13, 2017 at 10:07:53 AM | Revit Rendering Problem - Black Quadrants
Bennydablade
Bennydablade Avatar
Same issue here. Running 2017 and have not had this problem before. Also it is sporatic in that there is no consistency. I attached two images, One with and one without the missing area of the rendering. The only difference was that one was rendered with 300dpi and the other 150dpi. Both at the medium quality setting.
DO or DO NOT, There is no try!
Mon, Mar 13, 2017 at 11:43:11 AM | Revit Rendering Problem - Black Quadrants
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I would assume it is a memory problem.
Revit 2009 Rendering Problem(Black screen) [ 1 2 ]
Mon, Apr 1, 2013 at 2:45:28 PM
27
Lighting Fixtures show black in rendering but light in different angles
Tue, Jun 3, 2014 at 7:55:10 AM
How do you divide a building into 4 quadrants?
Wed, May 13, 2009 at 7:21:43 AM
Dividing Large Buildings into Quadrants
Wed, Aug 6, 2008 at 5:39:33 PM
Mon, Sep 22, 2003 at 2:21:53 PM
Page generation time: 1.7312
