Forums >> Revit Building >> Technical Support >> Ballaster Materials?
Sat, May 20, 2006 at 4:58:03 PM | Ballaster Materials?
gregmeurer
4.5 Stars: 9 Votes
I should know how to do this but can't figure it out for some reason. How do you change the material of the ballasters on the raillings. I can change the handrail but not the ballasters. Thanks for your imput.
Sun, May 21, 2006 at 5:31:53 PM | RE: Ballaster Materials?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
In your project use the project browser on the left, scroll down to families-->Railings-->the baluster family-->then select the type and edit it. Hopefully it should have a parameter here for the material if its been created with a parametric material. HTH.
Baluster not connecting to rail
Wed, Nov 30, 2011 at 5:32:02 PM
Adding materials into Revit's materials files
Thu, Jul 22, 2010 at 1:54:48 PM
Missing Materials
Wed, Jun 19, 2013 at 2:22:26 PM
Converting DWG materials to Revit Materials
Thu, Sep 13, 2012 at 3:50:29 AM
replacing materials in multiple family files?
Wed, May 6, 2009 at 7:13:40 AM
Page generation time: 0.3183
