Forums >> Revit Building >> Technical Support >> Revit 2017 - Topography contour lines visibility
Tue, Jan 10, 2017 at 4:35:08 PM | Revit 2017 - Topography contour lines visibility
mbeauvais
My contour lines below 0'-0" do not show up in any view. The surface is modeled correctly, but all contour lines below 0' do not show up in any views. I have never had an issue with this in any previous version of Revit.
I'm continuing to look for a solution, but since it's in all views, even 3D views, it seems like it's a bug (maybe a new feature, but a rather pointless one, if so).
I don't have any scope boxes on, I've tried adjusting the view range on the plan views. It's a residential project and we typically set the first floor height at 0'-0" for a residential project, that's why some of the grade is below 0'-0".
Wed, Jan 11, 2017 at 9:09:38 AM | Revit 2017 - Topography contour lines visibility
99.99% sure it is a user error of some sort.  Do you have imported CAD?
If the surface is modeled correctly, you had the countor lines at some point in time assuming you created them from scratch.
Goto a 3D view and do a zoom E.
Wed, Jan 11, 2017 at 10:36:07 AM | Revit 2017 - Topography contour lines visibility
mbeauvais
I created the topo from a cad file. If I move the topo up so that all points are above 0'-0" all the contour lines appear. As soon as it moves down to where I need it to be, the lines below 0'-0" dissappear. I did a zoom extents to humor you, it didn't change anything.
I started a new project, re-created the topo again. The topo lines dissappear as soon as they are at or below 0'-0".
Wed, Jan 11, 2017 at 10:46:28 AM | Revit 2017 - Topography contour lines visibility
Remove the CAD file from your view.  It is either that or another enity like a floor that is hiding your lines.
Wed, Jan 11, 2017 at 11:05:49 AM | Revit 2017 - Topography contour lines visibility
mbeauvais
The cad files were not visible, I've since deleted them and purged them. The contours still don't show up. My coworker is having the same issue on the project she is working on.
Perhaps, there is a maintenance update that we haven't installed yet, but it seems to be a flaw with 2017. Thankfully, it isn't critical for the time being.
Thanks anyway
Thu, Apr 12, 2018 at 9:55:31 AM | Revit 2017 - Topography contour lines visibility
rozicki
5 Stars: 2 Votes
I am also having this problem and I have never had it before, it seems like a 2017 glitch.  I drew my topo plan myself and the file is empty (no imports, etc.), I just started the drawing to see how much of a slope we are dealing with on site.
In my case it was primary and secondary contour lines that would show up above the 0' line, and strangely ONLY the (blue) primary contour lines showed up below the 0'.
WORK AROUND:  I changed the spacing of my (blue) primary contour lines closer together (to the spacing of the secondary contour lines).  This worked for me.   I can no longer can differentiate between primary and secondary contours, but it is better than nothing.  At least I have contours all the way down the slope, including beyond the 0' level where the house is.
Edited on: Thu, Apr 12, 2018 at 9:59:27 AM
Edited on: Thu, Apr 12, 2018 at 10:01:02 AM
Thu, Apr 12, 2018 at 10:01:59 AM | Revit 2017 - Topography contour lines visibility
rozicki
5 Stars: 2 Votes
Sorry, see attached image.  I couldn't delete the image in my original post.
Thu, Apr 12, 2018 at 12:32:45 PM | Revit 2017 - Topography contour lines visibility
This may help you.
Wed, May 5, 2021 at 1:55:53 PM | Revit 2017 - Topography contour lines visibility
aaronkennedy
WWHub, it still applies to today.  Thank you,
AAron
A Whole Lot of TOPOGRAPHY & CONTOUR LINE questions...
Tue, Nov 22, 2011 at 6:07:37 AM
matching contour lines from civil CAD when creating Topography (2019)
Fri, Dec 4, 2020 at 2:09:46 PM
Possible to place contour lines to toposurface instead of points?
Fri, Jun 1, 2018 at 2:57:52 PM
Hiding Contour Lines
Wed, Dec 16, 2020 at 10:00:03 PM
Visibilty of Contour Lines
Mon, Jun 21, 2010 at 9:32:46 AM
Page generation time: 1.6252
