Forums >> General Discussion >> Revit Project Management >> Demolition Phase
Tue, Jan 10, 2017 at 1:25:04 PM | Demolition Phase
HelmetFire
HelmetFire Avatar
Ladies & Gentlemen,I am familiar with the standpoint that there should not be a Demolition phase as it is technically unnecessary. However, I like the idea of having an intermediate phase where demolition can occur to keep demolished elements on a separate phase from temporary elements.Managing this additional phase does not seem to be an issue. Can anyone advise how this could end up going wrong for me? Thanks.
Tue, Jan 10, 2017 at 1:37:10 PM | Demolition Phase
It all depends on your requirements.  Revit has two settings, phase of an object and phases shown in a view.  Look at your view phase options: http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-DB104358-4D5A-494E-ACAE-BB8B4E72E572
Your demo phase I would assume is between existing and new.  You need to run a test project with a wview walls and doors, then assign the phases and demos and see what happens when you walk through these two switch settings in your view.
Tue, Jan 10, 2017 at 5:32:01 PM | Demolition Phase
HelmetFire
HelmetFire Avatar
Thanks WWHub!
Calculate Demolition
Fri, May 8, 2015 at 3:56:11 PM
Edit Demolition Profile Tool
Wed, Mar 1, 2006 at 4:43:33 PM
Phasing and Room Tag
Sun, Apr 17, 2005 at 8:26:22 PM
Maintaining "Phase Demolished" properties.
Thu, Jun 18, 2015 at 8:19:39 AM
Camera View not showing demolition lines dashed
Wed, Dec 11, 2013 at 2:24:15 PM
Page generation time: 0.8198
