Forums >> Community >> Newbies >> Celluar Beam Handles (grips)
Tue, Jan 10, 2017 at 5:46:01 AM | Celluar Beam Handles (grips)
PHITCH
Hi
Can anyone help, im tring to make my own celluar beam. (500 dia holes, 1000mm from the left, then 750 spaces)
Im manged to do this but the handles (grips) dont work (extend/trim the beam).
Any suggestion how to fix this.
Thanks in advance.
Tue, Jan 10, 2017 at 6:35:01 AM | Celluar Beam Handles (grips)
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Autodesk has an online library called seek. Try searching on it using the term castellated beam.
https://seek.autodesk.com/search/beams?q=category%3Aen_uk%3Aadsk%3Arevit-str%3A23.5.4+AND+catalog%3AINTERNAL~Revit+Structure&locale=en-uk
Tue, Jan 10, 2017 at 6:58:39 AM | Celluar Beam Handles (grips)
PHITCH
Thnaks for the reply. Thats similar to the one I editied. The grips don't work as a normal beam.
Tue, Jan 10, 2017 at 7:41:04 AM | Celluar Beam Handles (grips)
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
I've attached a couple that i had on file.
You can often find them on other forums like this:http://forums.augi.com/showthread.php?81054-Cellular-Beams
Some forums refer to them as Westok Beams.
Or create them yourself as per:
http://revit-waterman.blogspot.co.uk/2011/05/create-cellular-beam-family-method-part_09.html
Tue, Jan 10, 2017 at 8:05:17 AM | Celluar Beam Handles (grips)
PHITCH
Thanks for you help. But I cant seem to open your files. Is there anyway you can re-save them. Im using Revit 2016.
Shape Handles (Grips) not showing in 3D
Sat, Jan 16, 2021 at 5:06:20 AM
can“t see the door handles!
Tue, Jun 30, 2009 at 7:12:51 AM
12
blue triangle grips won't show on beam select -
Fri, Jul 9, 2010 at 8:54:46 PM
Lost Blue Handles
Mon, Jun 30, 2008 at 1:05:54 PM
11
Roof Shape Handles
Fri, Feb 6, 2015 at 10:28:04 AM
Page generation time: 0.0804
