Forums >> Revit Building >> Technical Support >> Rounding Issue in Schedules
Mon, Jan 9, 2017 at 9:12:31 AM | Rounding Issue in Schedules
jeclaudy
I am creating an Occupancy table and am trying to round up to the next whole occupant.
Area / Load Factor = Occupant Load.  I want to round "Occupant Load" up.
23856 SF / 100 SF = 238.56 Occupants.  I want this to round to 239.
1015 SF / 15 SF = 67.69 Occupants. I want this to round to 68.
1047 SF / 500 SF = 2.09 Occupants. I want this to round to 3.
I have entered "roundup (Area / Load Factor)" But Revit is calculating incorrect results.
23856 SF / 100 SF = Revit is now rounding this to 288... that's 49 people too many.
1015 SF / 15 SF = Revit is rounding this to 68, correct.
1047 SF / 500 SF = Revit is rounding this to 4... thats 1 too many
Why and how is this happening?
When I enter "(Area / Load Factor) + .4999" Revit is also giving me a wrong result.
23856 SF / 100 SF = Revit is now calculating 278.05, which would round to 278, still 39 people too many.
1015 SF / 15 SF = Revit is calculating 68.69, which would round to 69, 1 too many.
1047 SF / 500 SF = Revit is calculating 4.09, which would round to 4, 1 too many.
Thankful for any help on this issue!
Edited on: Mon, Jan 9, 2017 at 9:13:42 AM
Mon, Jan 9, 2017 at 9:36:40 AM | Rounding Issue in Schedules
marmiketin1
4.5 Stars: 10 Votes
Does this rounding error happen if you first calculate the exact number for occupants and then in a second parameter do the rounding? Also under the manage tab in project units you should check your rounding increment for area.
Mon, Jan 9, 2017 at 11:55:43 AM | Rounding Issue in Schedules
jeclaudy
The project Area rounding increment is set to 1.
Yes, the same error occurs if I create a second calculated parameter such as:
roundup (Occupant Load)
or
(Occupant Load) + .4999
Mon, Jan 9, 2017 at 2:07:07 PM | Rounding Issue in Schedules
marmiketin1
4.5 Stars: 10 Votes
I set up an occupancy table on my end with some dummy values and the roundup works for me. I am not sure what the problem is with yours but maybe try deleting the schedule and recreating it. Maybe Revit glitched out on you.
AREA SCHEDULES ROUNDING TO THE NEAREST
Wed, Dec 20, 2006 at 4:36:48 PM
Rounding in Formulas
Wed, Mar 13, 2013 at 8:49:48 AM
Dimension Rounding
Thu, Aug 23, 2007 at 2:54:31 PM
Area Tags - Rounding refuses to change
Tue, Feb 10, 2015 at 8:22:13 PM
Revit 2011 Array Qty Rounding Issue
Thu, Jun 16, 2011 at 10:16:06 AM
Page generation time: 0.2762
