Forums >> Revit Structure >> Technical Support >> Gaps is walls and corner
Mon, Jan 2, 2017 at 8:00:55 PM | Gaps is walls and corner
wizard8575
I tried clicking the light bulb to show all hidden, deleting the wall and recreating it I cant get those gaps to go away.
Mon, Jan 2, 2017 at 8:42:33 PM | Gaps is walls and corner
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Those gaps are where the walls created in previous phase intersect new walls. Change view phasing (phase filter) from ‘show new’, I assume that what your current setting is, to something that allows for the previous phase to be visible - ‘show previous + new’ for example.
Mon, Jan 2, 2017 at 10:28:06 PM | Gaps is walls and corner
wizard8575
I tried to override everything in the phase filter screen but it still does not show anything there.  Can I send someone the file to see what is causing this?
Mon, Jan 2, 2017 at 10:35:44 PM | Gaps is walls and corner
wizard8575
Ok I found the setting you were refering to I cahnged it to every setting  on the phase fileter but I did not show anything where those breaks are.
Tue, Jan 3, 2017 at 9:31:33 AM | Gaps is walls and corner
I'm not sure this is a phase issue, it may just be a modeling issue.  Are the two walls fully joined at the corner?- Check this out.
Tue, Jan 3, 2017 at 10:52:49 AM | Gaps is walls and corner
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
WW, the issue is not only at the corner. Looking at the other gap, to me, it looks like a phasing problem.
Wizard, can you upload your project so we can troubleshoot?
Tue, Jan 3, 2017 at 11:22:40 AM | Gaps is walls and corner
wizard - If it is a phase issue, remember there are two phase settings you have to control in a view - phase as well as phase filter.
Tue, Jan 3, 2017 at 6:19:06 PM | Gaps is walls and corner
wizard8575
I cant the file is too big to put on here.  I can do a dropbox share or ms cloud
Tue, Jan 3, 2017 at 7:46:24 PM | wizard8575
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Quoting wizard8575 from 2017-01-03 18:19:06
Please do.
You can also make a copy of your project and purge all unused a few times. It should greatly reduce the file size.
Tue, Jan 3, 2017 at 8:10:07 PM | Gaps is walls and corner
wizard8575
message me your email so I can share the file with you.
Wed, Jan 4, 2017 at 10:45:36 AM | Gaps is walls and corner
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
RevitCity doesn't have PM services.
Please upload here or use Cloud.
Wed, Jan 4, 2017 at 6:25:01 PM | Gaps is walls and corner
wizard8575
I added the file search for my name
Fri, Jan 6, 2017 at 9:50:38 PM | Gaps is walls and corner
#13
wizard8575
Has anyone been able to figure out my problem?
Wed, Jan 11, 2017 at 4:41:52 PM | Gaps is walls and corner
#14
wizard8575
Wow I have everyone stumped?
Wed, Jan 11, 2017 at 9:12:48 PM | Gaps is walls and corner
#15
wizard8575
I tried to move my building over about twice the distance of its size and the hole in the wall is gone now but the corner hole is still there.
Curtain walls
Mon, Nov 7, 2011 at 10:28:33 AM
Corner guards to snap to corner of wall
Tue, May 13, 2014 at 12:18:44 PM
Corner Mullions
Fri, Dec 6, 2013 at 11:05:58 AM
Footing Corner Problem
Tue, Jul 3, 2007 at 8:56:51 AM
Corner windows with variable angle
Tue, Dec 27, 2016 at 4:47:10 PM
Page generation time: 8.0198
